Installing an older version of firmware in an MNB-1000
  • Installing an older version of firmware in an MNB-1000
  • RandyDavis
    RandyDavis
  • Kim_Baze
    Kim_Baze
‎2018-09-06 10:16 AM
Last Updated: Guinan RandyDavis Guinan ‎2019-07-22 08:41 AM
Reverting to an older than installed version of the firmware is required.
TAC IA Series
  • I/A Series WorkPlace Tech
  • I/A Series MNB 1000
Prior to the 1.515 version of the firmware, it is not possible to revert to an older release of the firmware.
Firmware after 1.515 has the ability to be reverted. 1.515 is the oldest version the controller can be installed with.  If this procedure is required, please contact your countries Product Support for more information.
  • TAC IA Series
Tags (2)
  • 13692
  • RandyDavis19
0% helpful (0/3)
