Installing an EC/ES on another drive than the default C drive
  • Installing an EC/ES on another drive than the default C drive
  • Jonas_Brissman
    Jonas_Brissman
  • RandyDavis
    RandyDavis
Janeway Jonas_Brissman Janeway
‎2025-09-03 12:25 PM
Last Updated: Guinan RandyDavis Guinan ‎2025-09-03 12:28 PM
A customer would like to install an Enterprise Central(EC)  on the D drive instead of the C drive is that possible to do?
Building Operation Enterprise Server
In this case the customer is not allowed to install any files on the C drive so all EBO files should be installed on the D drive instead.
It is possible to install the EC or ES on the D drive, when installing you specify the programs and backups should be installed on the D drive instead of the C drive. And the programs and the backups are installed on the D drive as specified.
But there is some files that always will be installed on the C drive:
  • The backup is installed at D:\ProgramData\Schneider Electric EcoStruxure as it should but we also get a S2Connect folder at C:\ProgramData\Schneider Electric EcoStruxure.
  • When installing Workstation that will be installed on D:\Program Files (x86)\Schneider Electric EcoStruxure as the EC is installed there.
    But then we also get a GraphicsEditor folder and Workstation folder at C:\ProgramData\Schneider Electric EcoStruxure.
  • And then installing the License Administrator also add LicenseFiles folder at C:\ProgramData\Schneider Electric EcoStruxure
These files will always be installed on the C drive and this is not possible to change.
NOTE:  If Workplace Tech Editor is being used by Workstation on the PC, the accompanying Visio installation has to be installed, per Microsoft in the C: drive.
Tags (2)
  • JonasBrissman25
  • RandyDavis25
