Installing Webclient over the top of Cyberstation
Select a Country
  • Installing Webclient over the top of Cyberstation
  • Jonathan
    Jonathan
  • Alan_Wood
    Alan_Wood
‎2018-09-06 09:26 AM
Last Updated: DavidFisher Champion ‎2019-08-22 06:59 AM
If only Cyberstation was installed, but Webclient is needed will installing Webclient over the top work?
Andover Continuum
  • Webclient
  • Windows XP
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
At times a Webclient install is needed but a Cyberstation installation was done.
Trying to install over the top will not install the needed web components. The recommended installation of Webclient when Cyberstation has been installed first is as follows:
  1. Uninstall Cyberstation
  2. Reboot
  3. Install Webclient
  4. Run the following command after the install to re-register .NET framework with IIS.
    C:\Windows\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -i​
Tags (5)
  • 16680
  • activation
  • dcom
  • dotnet
  • explorer
