Installing MSDE on a new PC with SP4.
  • Installing MSDE on a new PC with SP4.
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:04 PM
Installing MSDE or upgrading I/NET on a PC that has SP4 (Service Pack 4) and an editor comes up displaying the ports that will be disabled when the program is installed, then goes away.
  • I/NET Seven
  • Windows SP4
  • MSSQL Server
 Ports in the MSSQL Server need to be enabled.
  1. Open Windows Explorer and go to C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SVRNTCN.exe.
  2. Double click on this file and enable the following files, Named Pipes and TCP/IP.
  3. Apply the changes and then close the editor SQL Server Network Utility.
  • TAC INET
  • 2066
