Installing I/NET and Vista on the Same PC Using I/NET with MSDE for File Equalization
  • Installing I/NET and Vista on the Same PC Using I/NET with MSDE for File Equalization
  • Derrick_Ratliff
    Derrick_Ratliff
  • CraigEl
    CraigEl
‎2018-09-10 03:17 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:54 AM
TAC INET, TAC Vista
  • I/NET 2.31 with MSDE
  • Vista 5.1.4 with SQL2005 Express
  • Windows XP
When Installing I/NET and Vista on the same PC and MSDE is desired for use with I/NET, I/NET must be installed first. If you are not using MSDE, please see Installation guidelines for installing I/NET and Vista on the same PC.
[video]
  1. Completely Remove I/NET, Vista and all versions of SQL and MSDE from the system. See Verify in Windows Registry all items are deleted after uninstall of I/NET Seven and MS SQL and How to uninstall and completely remove TAC Vista 5 for more details.
  2. Begin the I/NET Installation
  3. Select MSDE for the database installation.
  4. Complete I/NET and MSDE installation
  5. Install Vista
  6. Start Vista Server
  7. Start I/NET
  8. Configure I/NET as a Filemaster
  9. Build Database or restore from a backup.
Labels (2)
  • TAC INET
  • 6319
