Input String was not in a correct format when editing personnel in webclient
  • Input String was not in a correct format when editing personnel in webclient
  • Alan_Wood
    Alan_Wood
‎2018-09-10 01:21 AM
When editing a personnel object an error is received "Input string was not in a correct format" using 1.82 or 1.90.
Webclient
Windows XP
Windows Vista
Windows 7
Windows Server 2003
Windows Server 2008
Microsoft released .Net 2.0 SP2 which caused an issue with our code in the personnel area.
The version of Continuum you are using will determine the solution you need to use.
1.82 - Uninstall .net 2.0 SP2
1.90- Install the following hotfix
Click here to download
The issue was corrected in 1.91.
SavingPersonnelWebclient19.zip
  • 5978
