Initialization Failure Error
  • Initialization Failure Error
  • Benji
    Benji
  • Roger_Bently
    Roger_Bently
‎2018-09-06 02:50 PM
Error "Initialization Failure" when starting I/NET on a PC that has just been upgraded
I/NET Seven
I/NET Host Tool
Upgrading the version of I/NET on a PC requires that the database also be upgraded.
  1. Verify that the log in name that is used has Admin rights to I/NET
  2. Close I/NET and I/O Server, then start DB Create - log in
  3. Select the Upgrade Database radio button
  4. Force an upgrade on the database to reassign the passwords again
  5. Restart I/NET again and it should come up and give you the log in box, put your user name and password and it should start.
  • TAC INET
  • 2941
0% helpful (0/1)
