We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
Infinity Programs must be used when programming Infinity Controllers. Program objects (Non-Infinity programs) should not be used to program Infinity Controllers.
  • Infinity Programs must be used when programming Infinity Controllers. Program objects (Non-Infinity programs) should not be ...
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 02:05 PM
Can Program (non-InfinityPrograms) objects be used to program control sequences in Infinity controllers?
Programs (non-InfinityPrograms) in our Infinity Controller are not working reliably.
  • CyberStation
  • ACX
  • BCX
  • i2
  • B3
  • When we edit a Program object (non-Infinity Program) in our controller. when the program is saved it continues to work as if there was no change made to the programming.
  • Programs in our Infinity or Infinet controller are not working reliably.
  • Program objects are intended for use in the Workstation only, not in Infinity Controllers, Infinet Controllers or MSTP controllers.
  • When programming Infinity controllers or Infinet controllers you must use InfinityPrograms only.
  • When programming the Workstation, Programs (non-Infinity) must be used.
  • While program objects may or may not work marginally, they should not be used when programming Infinity Controllers.
  • 4706
This is a heading
