In MPM, it is not possible to save the Calendar Object
  • In MPM, it is not possible to save the Calendar Object
  • SaidSawan
    SaidSawan
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 09:21 AM
In the MPM, it is possible to creat a new Calendar object, but it is not possible to change or add information, it is not possible to Save.
MPM
The User Rights does not allowed you to Save your changes in the Calendar objects.
In the MPM, right click on the top right, where it says Management.
Select Permissions, and verify that the user that are logged in at the moment have permissions to Edit/View Calendar Objects.
  • EcoStruxure Building Expert
  • 16956
