Importing a Xenta 121-FC controller into StruxureWare Building Operation.
  • Importing a Xenta 121-FC controller into StruxureWare Building Operation.
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-06 10:10 AM
Xenta 121FC
How do you setup the Xenta 121-FC using StruxureWare Building Operation only, as all the config needs setting for 1 Return Temp. Cooling Only (AO type). Fan On/Off
The original process would require the use of LonMaker and ZBuilder to configure the Xenta 121-FC controller onto the LON network, before adding it to the StruxureWare Building Operation LON interface.
Version 1.4 introduces LNS device plug-in support to configure LonWorks® devices. StruxureWare Building Operation v1.4 supports third party software: OpenLNS. OpenLNS is only required on WorkStation machines used for configuration of LON® devices (e.g. WorkStation Pro machines). Automation Server and Enterprise Server databases are updated with any changes created with the plug-in.
With LNS device plug-in support, now ZBuilder can be used with SmartStruxure solution. Plus, all Xenta controllers are supported, including the X100 series – e.g. Xenta 121.
  • 13997
