Importing a Menta application for a Xenta 301 controller into StruxureWare Building Operation for a second time, cannot be saved.
  • Importing a Menta application for a Xenta 301 controller into StruxureWare Building Operation for a second time, cannot be sa...
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-06 10:16 AM
Importing a Menta application for a Xenta 301 controller cannot be saved.
Xenta
301
importing
Save
Saving
Importing a Menta application for a Xenta 301 controller, and then saving it, works correctly. If the application is modified in some way, requiring a second import, then this import cannot be saved.
This issue has been assigned to defect 22178, which is due to be fixed in release 1.5.
Work around.
  1. Delete the existing controller object, and then create a new controller object before importing the modified Menta application.
  • 13682
