Import Lon Variables from Excel
  • Import Lon Variables from Excel
  • RandyDavis
    RandyDavis
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2019-11-26 02:08 PM
Last Updated: Guinan RandyDavis Guinan ‎2019-11-26 02:18 PM
When importing Lon variables from Excel, all variables are created as Inputs, even though the "Direction" column in the Excel file says "Output".
Building Operation Workstation
A defect creates all Lon variables as inputs even if the variable is assigned direction as output.
 Create Lon variables with output direction manually.
  • JonasBrissman19
0% helpful (0/1)
