Implementing an Executive Privilege function through Access Level Door Types
  • Implementing an Executive Privilege function through Access Level Door Types
Guinan AdamSteele Guinan
‎2020-04-08 09:01 PM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:10 AM
A method is require to provide an Executive Privilege function to a Door to allow tailored credential requirements for specific Users.
Security Expert
Security Expert
Doors are currently set up for two credentials (Card + Biometric) but there is a need to allow certain Users access through those Doors without having to present the second credential.
The Access Level Door Type feature allows for this functionality. The option overrides the Door's Door Type with the one set in the Access Level (e.g. to allow a VIP to override 'Card + Biometric' to just 'Card' at a door).
Required Objects
  • Door Type
  • Access Level
  • User
Configuration
  1. In the Door Type set the Access Level Door Type to the door type you wish to use whenever Access Level Door Type is enabled - in this example it would be "Card".Fig.1 - Door TypeFig.1 - Door TypeFig.1 - Door Type
  2. In the Access Level enable the Use Access Level Door Type option.Fig. 2 - Access LevelFig. 2 - Access LevelFig. 2 - Access Level
  3. Assign the Access Level in step 2 to your User.Fig. 3 - UserFig. 3 - UserFig. 3 - UserFor a Video KB article showing a similar configuration process see:
    Security Expert user specific access vs standard door access
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele20
  • DavidKendrick22
