Security Expert user specific access vs standard door access
  • Security Expert user specific access vs standard door access
  • DavidChild
    DavidChild
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2020-05-19 01:06 AM
Last Updated: Sisko DavidChild Sisko ‎2020-05-19 01:07 AM
Is it possible to configure the system so that one or more users have different access requirements to the standard default access settings for each door?
Security Expert
Security Expert Client.
Although doors within Security Expert may be configured for Card Only, Pin Only and Card + Pin etc, in some circumstances it may be desirable to give an individual access which is different to a door’s normal settings.
For example
  • A cleaner may have to use Card + Pin where a regular employee may only require a Card.
  • The CEO of a company may only be asked for a Pin so that he or she can move around the building without needing a Card at all.
In each case the user level of security may more secure or less secure than the standard default settings of the door depending on the scenario.
The Security Expert Software Version 4.2.251.15.
The SP-C Firmware Version 2.08.843.
  • The default building door access is Card + Pin
  • Specific First Aid Technician door access should be Card Only to allow them to move more quickly through the building
[video]
  • EcoStruxure Security Expert
  • DavidKendrick20
