Identifying which Access Expert LDAP integration version is installed
  • Identifying which Access Expert LDAP integration version is installed
  • Alan_Wood
    Alan_Wood
Admiral Alan_Wood Admiral
‎2024-08-14 05:05 PM
on ‎2024-08-14 05:05 PM
Identify which Access Expert LDAP Active Directory Keep version is installed
EcoStruxure Access Expert
  • Access Expert Hosted V3
  • Access Expert LDAP Active Directory Keep Integration
  • Active Directory
Windows Control Panel Programs and Features doesn't indicate which version of the LDAP Active Directory Keep Integration is installed
  1. Login to Access Expert and the Instance that has LDAP Active Directory Installed
  2. Navigate to the General Configuration Tab> LDAP Agents LDAP
  3. Right Click on the LDAP agent and select View Event History
    Note: You may need to change the Priority from 50 to 0 and the Date Range to see an event
  4. Expand (Click the plus sign) of one of the LDAP Events (i.e LDAP Agent - Started)
  5. The version of the LDAP Active Directory Keep installation will show
  • EcoStruxure Access Expert
  • AlanWood24
