IO Module status indicates Low Power Mode
  • IO Module status indicates Low Power Mode
  • Derrick_Ratliff
    Derrick_Ratliff
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:03 AM
The IO Module does not report input signals and all physical outputs are turned off.
The IO module status LED blinks at a rate of one blink per second.
I/O Module
The IO module has been placed into Low Power Mode.
 I/O Module Low Power Mode
In order to save energy, an I/O module can be placed in low power. When an I/O module is in low power, the following conditions apply:
  • The I/O module does not report input signals and all physical outputs are turned off.
  • The Module status reports low power.
  • The I/O module's LED pattern indicates low power (the slowest green LED blink pattern, approximately once every 3 seconds).
When you set an I/O module to low power, the software turns off all outputs.
When you want to recover an I/O module from low power, there are several points to consider:
  • Make sure all I/O module Output values are set to a safe level before a return to normal power conditions. This prevents "power surge" conditions.
  • After normal power resumes, the Output values set are reached immediately after any timing delay occurs.
Setting and Recovering an I/O Module from Low Power
Place an I/O module in low power mode in order to save energy and then recover that module later.
To set and recover an I/O module from low power
  1. In WorkStation, in the System Tree pane, expand the IO Bus.
  2. Click the I/O module that you want to put in Low power mode.
  3. Click File and then Properties.
  4. Under Configuration Settings, in the Low power box, select True.
  5. Click OK to change the value and close the Properties tab.
If the physical I/O module, shown in the System Hardware folder, matches the logical I/O module defined in the I/O Bus, the I/O module goes into Low power.
After the physical module enters low power, the Module status attribute in the Status Information area displays Low power.
  1. In the System Tree pane, expand the IO Bus to recover from low power mode.
  2. Click the I/O module to recover.
  4. Under Configuration Settings, in the Low power box, select False.
  5. Click OK to change the value and close the Properties pane.
If the physical I/O module, shown in the System Hardware folder, matches the logical I/O module defined in the I/O Bus folder, the I/O module exits from low power.
After the module resumes operation from low power, the Module status returns to the status it had before it went into Low power.
NOTE: If unable to change the Low Power property:
  1. Export the contents of the I/O module
  2. Deleted it from the AS
  3. Re-add it to the AS
  4. Import the XML back into the module
  • 14416
100% helpful (1/1)
