IDWorks on a Remote Client does not connect to the SQL Db
  • IDWorks on a Remote Client does not connect to the SQL Db
  • Tom_Poovey
    Tom_Poovey
  • CraigEl
    CraigEl
‎2018-09-11 01:00 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 11:22 PM
IDWorks 6.x (on a Remote Client) does not connect to the SQL with Windows 7 64 Bit.
TAC INET
  • Datacard IDWorks 6.x
  • Windows 7 64-bit
  • I/NET 2.43 and above
You have to manually install a 32 Bit ODBC connection for this to work correctly.
To resolve this issue, start the EXE file located at: C:\Windows\SYSWOW64\odbcad32.Exe.
NOTE: This is NOT the ODBC that is in the Control Panel on the PC. Once you start the EXE file, set this new ODBC Connection up by following the steps that are listed in Setting up ID Works on a Remote Client PC.
  • TAC INET
Tags (5)
  • 12724
  • 64bit
  • Datacard
  • ID Works
  • Remote Client
