IDISCWAND - Alternative Availability
  • IDISCWAND - Alternative Availability
  • RobertAndriolo
    RobertAndriolo
‎2018-09-10 02:19 AM
Trying to find the IDISC Reader Part number IDISCWAND
I/NET
IDISC
The model IDISCWAND tool is no longer an active product with Schneider Electric.
The model IDISCWAND tool is no longer an active product with Schneider Electric. The following information describes how you can acquire the necessary components to form the IDISCWAND.
The IDISCWAND is comprised of two component devices as follows -
  1. The hand held wand (602063-0002) the hand probe used to contact the IDISC buttons for reading and enrollment of the access control credential into the system. The wand requires an Adapter to allow system communications to the IDISC. The wand can be purchased from Maxim Integrated Products using the Maxim part number DS9092GT#.
  2. The second component is the RS232 communications port “Adapter” (602073-0010). The cable from the wand (shown above) plugs into the RJ11 port on the Adapter. The other end of the Adapter is a standard D-subminiature 9-pin RS232 connector. The D-sub end of the Adapter mates with the 9-pin RS232 communications port of the PC workstation (TAC I/NET Seven Host), or the RS232 port created with a USB to Serial port adapter. The Adapter can be purchased from Maxim Integrated Products using the Maxim part number DS9097U-S09#.
The “#” symbol at the end of the two part numbers designates RoHS compliance and is the only version currently listed on the web site referenced below. Parts without the “#” would be functionally equivalent. The part number DS9092GT# Wand and DS9097U-S09# Adapter can be purchased from Maxim Direct at - https://www.maximintegrated.com/en.html
Enter the part number in the “Price and Availability” search window to see price and lead time on the item, and place an order.
View PDF document here.
  • TAC INET
  • 5759
