I/NET third party password (INetThirdParty) login not working with I/NET Seven 2.40 and above
  • I/NET third party password (INetThirdParty) login not working with I/NET Seven 2.40 and above
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 02:14 PM
Unable to login in to the I/NET SQL database using the default password for login name  INetThirdParty.
Seven ODBC Settings can not be changed using the INetThirdParty login, receive 'SQL Login Error: 18456'
What is the I/NET third party password?
Windows XP, Windows Server 2003, Windows 7
The I/NET Seven INetThirdParty password needed to comply with security requirements for Windows 7 and SQL 2008.
The INetThirdParty password is now PassInetDb3p_SE (case sensitive). for  I/NET Seven 2.40 and above
For Inet 2.31 and below its PassInetDb3p
  • TAC INET
  • 4418
