I/A Series R2 BACnet Alarm Fails with E_BACNET_UNRESOLVED_DEVICE_ADDRESS
  • I/A Series R2 BACnet Alarm Fails with E_BACNET_UNRESOLVED_DEVICE_ADDRESS
  • CraigEl
    CraigEl
  • WaynePeters
    WaynePeters
‎2018-09-06 10:09 AM
Last Updated: Administrator CraigEl Administrator ‎2025-12-04 06:17 PM
An I/A Series R2 station fails to send BACnet alarms to a third-party system. The error log shows:
tridiumx.bacnet.BACnetException: E_BACNET_UNRESOLVED_DEVICE_ADDRESS.
TAC IA Series
  • I/A Series R2
  • BACnet
The station does not contain a BACnet device object for the target device. Without this object, the system cannot resolve the device address required for alarm routing.
  1. Ensure the station includes the BACnet device object for the target device. This object provides essential details such as IP address and device instance.
  2. Verify the target device is online and capable of receiving BACnet alarms.
  3. Use BACnetUtility and the learnNetwork command to create BACnet device objects for all target devices.
  4. Refer to the I/A Series R2 BACnet Integration Reference Guide (section: Configuring for BACnet Alarm Generation) for detailed steps.
Additional Notes:
  • Only Niagara objects exposed as BACnet objects (AIs, AOs, BIs, BOs, MSIs, MSOs) can generate BACnet alarms.
  • Alarms are not regenerated if the BACnet device is offline during transmission.
  • Enterprise Server cannot generate alarms for subordinate stations; each station must be configured individually.
  • TAC IA Series
Tags (2)
  • 14068
  • CraigEllis25
