How to upgrade to to version 1.9.1 from a 1.5.0, 1.6.1 or 1.7.1 SBO system with LON devices
  • How to upgrade to to version 1.9.1 from a 1.5.0, 1.6.1 or 1.7.1 SBO system with LON devices
‎2018-09-11 11:39 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:46 AM
  • Does the entire SBO system need to be upgraded to 1.5.0.171xx, 1.6.2.12xxx or 1.7.2.111xx before upgrading to 1.9.1 if the network includes LON devices?
  • Can SBO be upgraded directly to 1.9.1 from 1.5.X, 1.6.X or 1.7.X?
  • SBO Workstation 1.5.0/1.6.1/1.7.1
  • SBO ES 1.5.0/1.6.1/1.7.1
  • SBO AS 1.5.0/1.6.1/1.7.1
  • SBO AS-P 1.7.1
In systems that have SBO servers that already are hosting LON devices based on LonWorks imported device templates (.XIF) or resource kits (.DRF), the servers need to be prepared before an upgrade from versions 1.5/1.6/1.7 to version 1.9.1. Even servers where device templates (.XIF) or resource kits (.DRF) are just imported, and no devices or network variables are created yet, the servers have to be prepared before the upgrade.
Please see section 9.2.3 of SBO 1.9.1 Release Notes. Although it says "Steps to upgrade a 1.6.2/1.7.2 multi-server system" you don't have to upgrade the AS or ES etc, even if they run 1.6.1/1.7.1, it's only SBO Workstation that need to be hotfixed.
Links to the different Workstation hotfixes can be found Server with LonWorks devices - TPA-SBO-17-0002.00 - Links to hot fixes.
If there are no LON devices in the system, you may upgrade directly to 1.9.1 from 1.5.X/1.6.X/1.7.X
  • 19203
34% helpful (1/3)
