How to test the online status of all nodes at once in NL220
  • How to test the online status of all nodes at once in NL220
  • Cody_Failinger
    Cody_Failinger
‎2018-09-11 03:58 AM
It takes a lot of time to test each node in a database to verify that they are all truly online.
  • NL220
Instead of checking each node in NL220 one at a time, a test can be performed that will check all nodes at one time.
  1. Right click on the subsystem in the network tree of NL220
  2. Click on Nodes
  3. Make sure that "Recursive commands on subsystem" is checked
  4. Click on Network
  5. Click Test
NL220 will now go through the entire database and perform a test on each node.
Labels (2)
  • TAC IA Series
  • 13395
