How to set up a door for keypad OR card validation
  • How to set up a door for keypad OR card validation
  • Carl_Slack
    Carl_Slack
  • Alan_Wood
    Alan_Wood
  • AbeMeran
    AbeMeran
‎2018-09-06 02:54 PM
Sample Plain English program to set up a door to allow for either keypad OR card validation.
  • Continuum
  • Plain English
  • Infinity
  • NetController
Allowing the NetController to respond to a keypad as well as a card reader allows for flexibility in the security solution.
How do I setup a door for keypad OR card validation
Create the following InfinityProgram in the NetController for each door. Change each program to the correct door name.
NOTE: If using this program, make sure that you do not have validate pin mode selected on the entry reader tab of the door editor.
'Looping, AutoStart Program
'Change officedoor to the name of your door
Watching:
IF officedoor\doorfault IS 2 THEN '0 for normal operation 2 if Fault (Tamper) detected
officedoor\entrynormmode = 8 'PINMode
officedoor\entrynocommmode = 8 'PINMode
GOTO Counting
ENDIF
Counting:
IF TS > 5 THEN 'Wait 5 seconds before switching back to SiteMode + CardMode
officedoor\entrynormmode = 3 'SiteMode + CardMode
officedoor\entrynocommmode = 3 'SiteMode + CardMode
GOTO Watching
ENDIF
Press the # key once, it will place the door in PINMode (8) for the 5 seconds then back to SiteMode+CardMode (3).
Here are the available EntryNormMode and ExitNormMode values
SiteMode = 1
CardMode = 2
GeneralMode = 4
PINMode = 8
If you plan to use more than one add the two numbers together (Example: SiteMode + CardMode + PinMode = 11)
Here are the available DoorFault values
1 = Database of doors, areas, and personnel is not functioning normally
2 = Entry Keypad is being tampered with
4 = Exit Keypad is being tampered with
8 = Entry Card Reader is being tampered with or has failed
16 = Exit Card Reader is being tampered with or has failed
My Test case:
I created a person with a valid card and a valid PIN. When I used the card the door would open, after relock I pressed the # and immediately entered the PIN plus the #, the door unlocked.
If you have a door switch you could probably use it instead of the 5 second timer this would give you a little more control over the door so that the next person in line (with a card) would not have to wait.
CyberStation (v1.52.0.20021120)
NetController (v1.520010)
AC1 (v22)
HID ProxPro with Keypad
Note: this works on an ACX(5740/5720) also
IMPORTANT:
The sample PE program above only sets the EntryNormMode of the door. The program needs to set also the EntryNoCommMode and possibly the EntryNodataMode. If the door is a dual reader door then the corresponding attributes on the exit side of the door must also be set.
  • 2770
100% helpful (3/3)
