How to run a controller program (InfinetProgram) when the controller first starts up?
  • How to run a controller program (InfinetProgram) when the controller first starts up?
  • AdamSteele
    AdamSteele
‎2018-09-06 12:20 PM
Continuum Controllers Plain English
Need to be able to set specific parameters at startup time of the controller. For example, with a VAV controller, you may want to re-calibrate the closed position of a damper by having this done at power up. This will allow just a power cycle of the controller after been serviced locally.
Have a program run at start-up of the controller that resets any required parameters back to default values.
To do this, create a Program that sets these values and then configure that Program with a FlowType of 'FallThru' and with AutoStart set to 'True'. This will run the program only once at start-up of the controller.
  • 7960
