How to recover the operator password for an SP-C-WEB
  • How to recover the operator password for an SP-C-WEB
Commander Hernan_Urueña Commander
‎2022-10-30 10:35 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:33 AM
Operator password for SP-C-WEB has been lost and unable to login to the controller.
EcoStruxure Security Expert
SP-C-WEB
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
The SP-C-WEB operator passwords are unable to be recovered.
  1. Default the controller using the jumper to bridge reader port 2 [1]Figure 1. Connecting Wire LinkFigure 1. Connecting Wire LinkFigure 1. Connecting Wire Link
  2. Once the controller is back online set the default admin password.
  3. Then restore a previous backup of the sites database containing the site configurationFigure 2. Restoring Database BackupFigure 2. Restoring Database BackupFigure 2. Restoring Database Backup
  4. When the backup is restored the operators are not overwritten so the one you just setup during the commissioning can be used to login to the SP-C-WEB.
[1] SP-C-WEB Security Purpose Web Enabled Controller Installation Manual
  • EcoStruxure Security Expert
Tags (2)
  • HernanUruena22
  • HernanUruena25
