How to integrate Active Directory with Security Expert
Select a Country
  • How to integrate Active Directory with Security Expert
  • AdamSteele
    AdamSteele
AdamSteele Champion
‎2019-06-13 06:57 PM
Understand methods for integrating Security Expert with Active Directory for creation and management of Operators and Users.
EcoStruxure Security Expert
  • Security Expert
  • Active Directory
  • SX-AD-OPR
  • SX-AD-USR
  • SX-DB-SYNC
  • PowerShell
Security Expert Active Directory Integration provides synchronization and authentication for Active Directory users enabling organizations to leverage on the user management and security policies that Active Directory provides. This article looks at the details between each integration option.
There are four options for Active Directory Integration.
1. Default Windows Authentication option.
  • This allows for logging in to Security Expert with the Windows User account credentials which could include AD users if on a Domain.
    • Operator object must be created in Security Expert and configuration of windows authentication option has some specific steps to be followed for it to work.
      Unable to login to Security Expert using Windows Authentication
    • Remember to use syntax "<domain>\<username>" for the username when configuring the Operator for a Windows user ON a  Domain.
    • Remember to use syntax "<computername>\<username>" for the username when configuring the Operator for a Windows user that is NOT on a Domain.
  • No extra license is required for this.
2. SX-AD-OPR : License for adding Security Expert Operators from AD.
  • Security Expert Operators will need to be added manually using the following steps:
    1. Navigate to Operators and click Add.
    2. Check the Windows Authentication box.
    3. Click the ellipsis adjacent to the User Name.
    4. Use the Active Directory Users window to search for the AD credentials you wish to use.
  • Once the Operator has been added, you may check the Windows Authentication option when logging in.
3. SX-AD-USR : License for adding Security Expert Users from AD.
  • This will allow an active directory domain windows group to be periodically polled for updates that will in turn update the Users in Security Expert.
    • Individual options for importing users, disabling user if AD user is disabled, disabling user if AD user is deleted.
    • Only user names are imported, other than this only action can be disabling of users in Security Expert. No other details can be updated or added.
  • See application note AN-141 Security Expert LDAP User Import Configuration.
4. SX-DB-SYNC : Data Sync Service with Powershell script.
  • Powershell script pulls user details out of AD and writes to a CSV file that the Data Sync Service then imports into Security Expert.
    • Can perform more functions than SX-AD-USR as any attribute from AD users can be mapped to any attribute in Security Expert users.
    • Will require powershell experience as the sample script may need to be modified.
  • See SEC-APP-03-1.0 – SX AD integration using PowerShell for a sample script and in-depth details on how to configure this solution for importing User data.
  • See SX-DB-SYNC Security Expert Data Sync Service Integration Guide for details on setting up and using the Data Sync Service. The guide is in the package ZIP file.
  • EcoStruxure Security Expert
Tags (5)
  • AdamSteele19
  • AdamSteele22
  • AdamSteele23
  • AdamSteele24
  • AdamSteele25
100% helpful (3/3)
