How to find the Facility Code and Card Number
  • How to find the Facility Code and Card Number
‎2018-09-07 04:02 AM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:55 AM
Can I take a 26 bit Wiegand Hexadecimal Card Number format and find out what the Facility Code and Card Number are?
TAC INET
Need to discover the Facility Code and Card Numbers
Yes you can do this. This document will show you the process on how to determine these values: 26 Bit Wiegand Format
Also see Conversion from I/NET hexadecimal code to Continuum Facility/Card Number for an Excel utility to perform this conversion.
  • TAC INET
  • 3134
