Conversion from I/NET hexadecimal code to Continuum Facility/Card Number
  • Conversion from I/NET hexadecimal code to Continuum Facility/Card Number
‎2018-09-07 05:57 AM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:55 AM
I/NET uses a different "large number" hexadecimal format to represent individual cards.  To convert to a Continuum system, these must be decoded into Facility Codes and Card Numbers.
Andover Continuum, TAC INET
I/NET Seven Security converted to Continuum
Different representations of individuals in the two systems.
  1. Download the "ZIP" file here conversion Excel spreadsheet.
  2. Press the "Clear Values" button to zero out the inputs.
  3. Select the correct format between the four options:
    • 26-Bit Wiegand
    • 32-Bit Wiegand Format (CSI)
    • 35-Bit Wiegand Format
    • 37-Bit Wiegand Format
  4. Enter the hexadecimal value and the Facility Code and Card Number will populate automatically.
Labels (2)
  • TAC INET
DecodeLargeNumber2CardNumber.ZIP
Tags (3)
  • 4574
  • Decode Large Number
  • inet
