How to export personnel records to a .CSV file in Continuum
  • How to export personnel records to a .CSV file in Continuum
  • CraigEl
    CraigEl
  • sesa116871
    sesa116871
  • Sampath_Konda
    Sampath_Konda
‎2018-09-09 09:51 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:04 PM
Continuum Explorer
-none-
1.  In Continuum Explorer, right-click on the Personnel folder, and select View.  This will open the PersonnelClassDefault Listview that will contain all personnel records
2.  In the listview, select Object > Export All.  The Open dialog box will appear.
3.  Create or select a folder on the hard drive and indicate a file name (*.csv), then click Open. If the file is newly created, it will ask you ant to create it.  Select Yes.  The CSV file will be created.
4.  Have a look at the video tutorial:
http://community.se.com/videos/1562
  • 5265
