How to decrypt bit information of a xDriver point (Integer/Word) value.
  • How to decrypt bit information of a xDriver point (Integer/Word) value.
  • SangKim
    SangKim
‎2018-09-06 01:40 PM
Most of the xDriver points provide bit (binary) information in a word(integer) point in order to save register address. In order to interpret/decrypt the bit information out of the word(integer) value, PE programming is required.
Net Controller (CX99xx, CX96xx)
bCX controller (bCX4040)
ACX5740/5720
Bit information is displayed as a number in the controller when read in to.  Need to have PE function to decrypt the number in to each bit information.
Create InfinityProgram in the Controller as below;
Numeric locNum1
Numeric nBit0, nBit1, nBit2, nBit3, nBit4, nBit5, nBit6, nBit7, Numeric nBit8, nBit9, nBit10, nBit11, nBit12, nBit13, nBit14, nBit15
Line ReadAndSet
  locNum1 = CIAlarms ' Read the xDriver point and set to local point.
  Goto AAA
Line AAA
  ' Decrypt each bit information from the locally mirrored point.
  nBit0 = (locNum1 bitand 2 ^ 0) > 0
  nBit1 = (locNum1 bitand 2 ^ 1) > 0
  nBit2 = (locNum1 bitand 2 ^ 2) > 0
  nBit15 = (locNum1 bitand 2 ^ 15) > 0
  Goto BBB
Line BBB
  ' Do something here for each nBit0~nBit15 such as below
  ' If nBit0 then
  ' set InverterTempAlarm = On   'Set the global point to ON
  ' Else
  ' set InverterTempAlarm = Off   'Set the global point to OFF
  ' Endif
   Goto CCC
Line CCC
  ' Wait for 15 seconds and send to the first line to read the xDriver point again.
  If TS < 15 then Goto CCC
  Goto ReadAndSet
Line E
  If TS < 30 then Goto E
  Goto ReadAndSet
  • 5472
