How to customize the active alarm view in status line mode to remove the weekday from the date field.
  • How to customize the active alarm view in status line mode to remove the weekday from the date field.
  • AdamSteele
    AdamSteele
‎2018-09-11 04:32 AM
Is it possible to customize the active alarm view in status line mode to remove the weekday from the date field?
Continuum Cyberstation
Do not want the name of day  (weekday) being shown in the Active Alarm View.
The weekday can be removed from being displayed in the Active Alarm View. You will need to change the "Long Date" field in your Windows Regional Settings to remove the preceding weekday name.
Change "dddd,d MMMM yyyy" to "d MMMM yyyy" and you will see that the entry in the alarm bar goes from having the name of the day shown;
To only showing the day, month, and year;
  • 13868
