How to configure a SetPoint in EcoStruxure Building Operation
  • How to configure a SetPoint in EcoStruxure Building Operation
  • DavidChild
    DavidChild
  • AdamSteele
    AdamSteele
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2019-11-08 02:23 AM
Last Updated: Sisko DavidChild Sisko ‎2019-11-08 02:24 AM
Configuring a SetPoint in EcoStruxure Building Operation so that the set value of the SetPoint is retained after a Warm or a Cold Start rather than defaulting to zero.
  • Building Operation Automation Server Premium
The value retention configuration is not held in the initial properties page of the Analogue Value when used as a SetPoint.
Navigate to the actual value within the properties page of the Analogue Value. On the right hand side of the GUI there is a Configure button.
Pressing on this button then takes the user to a sub menu where the Retain level option can be enabled.
Once enabled it is then possible to decide whether the SetPoint needs to retain its value under a Warm Start or a Cold Start condition.
  • DavidKendrick19
75% helpful (3/4)
