How to configure Keypad Duress and Door Duress alarms
  • How to configure Keypad Duress and Door Duress alarms
  • AdamSteele
    AdamSteele
  • RobertAndriolo
    RobertAndriolo
Guinan AdamSteele Guinan
‎2022-07-14 01:23 AM
on ‎2022-07-14 01:23 AM
Require details on how to configure duress events from Doors and Keypads to be registered and displayed as alarms.
EcoStruxure Security Expert
Security Expert
Door and Keypad duress trouble inputs are not configured to trigger alarms when activated.
Use an Event Filter to filter for specific Trouble Input events and then setup an Alarm to use that Event Filter.
  1. Configure an Event Filter for duress events by creating an event filter with the Event Type:
    1. Trouble Input<TROUBLE_ZONE_NAME>Opened
  2. If you need an alarm for when the duress trouble input is closed then also add:
    1. Trouble Input<TROUBLE_ZONE_NAME>ClosedEvent TypesEvent Types
  3. Then on the Records Tab add the specific Trouble Input(s):
    1. User Duress Code
    2. Door DuressRecord FilterRecord Filter
  4. Create a new Alarm record under Events | Alarms.
  5. Add this Event Filter, created in step 1, to the Alarm.
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele22
  • AdamSteele24
