How to change the power line frequency setting on the 7716, 7718 and 7756
  • How to change the power line frequency setting on the 7716, 7718 and 7756
‎2018-09-07 12:09 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:44 AM
How do I change the power line frequency setting on the 7716 / 7718 / 7756?
I/NET
Hand Held Console (HHC)
Warning
How do I change the power line frequency setting on the 7716, 7718, 7756?
Physically remove the I/O points from the controller. See TCON 096 for details.
  1. Using the HHC, press [Code] , 92, [Enter] to select the AC line frequency
  2. Press [Inc] or [Dec] to switch between 50 an 60 hertz
  3. Press [Enter] to accept your choice
  4. After downloading the software and database, place the external points on the 7716 (or 7718 and 7756)
  5. Place the controller on the LAN
Note:  Code 92 is not required for any of the 779x Interface's. Entering this code on the Hand Held Console will produce the error LED to illuminate.
  • TAC INET
  • 1476
