How to automatically disable access for Personnel who's expiry date has passed?
  • How to automatically disable access for Personnel who's expiry date has passed?
  • AdamSteele
    AdamSteele
‎2018-09-06 12:18 PM
Continuum Access Control
Want to automatically disable Personnel who's cards have gone beyond the expiry date.
The below code sample can be used as a basis to provide this feature.
It is a fallthru Workstation Program that can be triggered from one of the time related SystemVariables such as Hour or Minute.
It uses the OpenList function to go through all Personnel in a specific folder and compare their expiry dates to the current Date and then disables them if required.
'Fall thru program that will search through the Personnel class for
' an expiration date that is less than today’s date.
Object oAPerson
Numeric nResult
Line 1
  nResult = OpenList("Personnel", oAPerson, Root\CardHolders) 'specify CH path
Line 2
  If nResult = Success then
    While GetObject(oAPerson) = Success
      'The next line will fail when the Expiration Date attribute is greater than 12/31/2037 (12/31/2099, by default)
      If (Date > oAPerson ExpirationDate) then
        Set oAPerson State = Disabled
      Else
        Set oAPerson State = Enabled
      Endif
    Print oAPerson Name, " is ", oAPerson State 'prints to message window for testing
    Endwhile
  Endif
  • 8016
