How to accommodate sites that require the use of more than the maximum four site codes allowed.
  • How to accommodate sites that require the use of more than the maximum four site codes allowed.
  • AdamSteele
    AdamSteele
‎2018-09-10 03:09 AM
How can I use more than four site codes in Continuum?
Continuum Access Control
ACX57xx
CX9900
CX9680
CX9702
ACX781
Continuum will only support four site codes.
A workaround to this is to use the Custom Wiegand card format to create unique card numbers. To do this, we will set the custom format to allow a unique 24-bit card number to be created from the existing 8-bit site code and the 16-bit card number.
Download Instructions
LLA6133 Instructions.zip
Tags (2)
  • 6133
  • sitecodes
100% helpful (1/1)
