How to Node a BAS Outstation – Node Commands Explained
  • How to Node a BAS Outstation – Node Commands Explained
  • CraigEl
    CraigEl
  • DavidChild
    DavidChild
‎2018-09-10 03:47 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 12:15 AM
How to correctly node a BAS outstation and what node commands are available.
Satchwell BAS & Sigma
  • Satchwell BAS
  • UNC532
  • UNC496
  • UNC596
Users may be unfamiliar with the correct node commands or the process for node configuration using terminal utilities.
To node a BAS outstation, follow these steps:
  1. Connect to the Controller:
    • Use either the Pocket Terminal Utility or HyperTerminal.
    • Plug the lead into SK1.
    • The terminal should display "ready".
  2. Use the Following Commands:
    Command Description
    O Initiates the node command (Note: This is the letter O, not zero).
    H132 Used for specific controller types (⚠️ Not applicable to x96 controllers).
    S Displays the current node setup.
    Note: Always verify controller compatibility before using H132.
📎 Attachments
  • POCKTERM.ZIP – Pocket Terminal Utility
  • Satchwell BAS & Sigma
POCKTERM.ZIP
Tags (2)
  • 6501
  • CraigEllis25
