How to Export Personnel Photos.
  • How to Export Personnel Photos.
  • BillNeville
    BillNeville
‎2018-09-06 11:12 AM
Photo export
CyberStation
Need to export photos in personnel records.
When a personnel record in Continuum has a photo included, the photo can be exported as a JPG file by doing a "Send to Text File" for that record.
The JPG file will be created with the following naming convention:  NamePhoto.jpg where name is the object name (uiname).
The JPG file will be created in the same directory as the DMP file. If multiple personnel objects containing photos are dumped out, a JPG for each will be created in the directory of the DMP file.
  • 10963
