How many relay packs could be connected simultaneously to one SE7300 or SE8300?
  • How many relay packs could be connected simultaneously to one SE7300 or SE8300?
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 09:24 AM
How many SC2300 could be connected to one SE7300 or 8300?
SC3000 SE7300 SE8300
Inputs from the relay packs could not be connected in parallel.
It is not possible to connect inputs in parallel, therefore you could only connect one relay pack to one device.
  • EcoStruxure Building Expert
  • 16789
