How is the "Foreign Device Table" viewed in a SmartStruxure Enterprise (ES) or Automation Server (AS)?
  • How is the "Foreign Device Table" viewed in a SmartStruxure Enterprise (ES) or Automation Server (AS)?
  • sesa139513
    sesa139513
  • AbeMeran
    AbeMeran
  • sesa125819
    sesa125819
‎2018-09-11 07:26 AM
Viewing the Foreign Device Table in an ES or AS.
BBMD
FDT
Unable to locate where the Foreign Device Table can be viewed.
The Foreign Device Table is located  under the server  in the System/Modules/BACnet Devices/FDT folder
First create the BBMD, which will be located under the BACnet Interface/IP Network folder.
 The Foreign Device Table can then be viewed by going to System/Modules/BACnet Devices/FDT.
Note that the foreign device table is read-only, it displays information about what other devices have been configured as foreign devices pointing to this device (the BBMD).
NOTE:
In 1.5 the Foreign Device Table has been moved as a new tab on the BBMD object.
  • 15946
