How do you get a list of previous operator history on a specific point from the active alarm view?
  • How do you get a list of previous operator history on a specific point from the active alarm view?
  • sesa119747
    sesa119747
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:33 PM
CyberStation
A report will need to be attached to a graphic to see a point's operator text history from the active alarm view.
  1. Create a report for this point to get the operator text
    Source Tab
    Data Source: AlarmEvent
    Report Type: Alarms-for-an-event-object-with-alarm-enrollment
    Type: Text
    Filter Tab
    Path: select the controller the point is in
    Member Object: Select the point you need
    Time Interval or Log Filter for the desired range
  2. Setup a graphic page with a button to launch the report
    In the properties of the Active Button
    Action: Open Object
    Object: This is the path to the report you created in step 1.
  3. Setup the point on alarm tab to open the graphic
    In the point editor that you want the operator history from, select the Graphic field by setting the path to graphic that contains the button for the report from step 2.
  4. When the alarm is triggered in the active alarm view, click on the alarm then the Pinpoint button in the tool bar.
    This will launch the graphic with the button for the report you created.
  5. Click on the button to launch the report which will contain the operator history for that point.
Notes: For multiple points, the same graphic can be launched each time, but separate reports will need to be created for each point and a different button to launch those reports.
  • 3649
