The site has a Niagara R2 Enterprise Server and a UNC with multiple MSTP controllers connected.
TAC IA SeriesEnvironment
- Niagara R2 Enterprise
- UNC
- MSTP controllers
Follow these best practices to improve BACnet MSTP performance:
Remove Unused BACnet Objects
- Delete unnecessary BACnet objects learned into the station.
- Move non-critical objects from Poll-Always to Poll-on-Demand containers.
Optimize Controller Addressing
- Ensure all MSTP controllers are consecutively addressed.
- Avoid gaps in addressing to reduce communication delays.
Benefits of Consecutive Addressing:
- Faster Token Passing: Token moves quickly without searching for missing addresses.
- Reduced Token Search Overhead: Minimizes wasted polling cycles caused by gaps.
- Easier Troubleshooting: Simplifies device identification and network verification.
- Optimized MaxMaster Setting: Predictable and efficient configuration.
Set Correct MaxMaster Value
- Configure MaxMaster in all controllers and the UNC to two greater than the highest MSTP address.
- Example: If highest address = 20, set MaxMaster = 22.
- Leaving MaxMaster at 127 with only 20 controllers causes unnecessary token searches.
Adjust MaxInfoFrames
- Set MaxInfoFrames in the UNC or MNB-1000 to between 5 and 20.
- Default is 1, which results in sluggish updates.
- Start at 5 and increase gradually to find the optimal performance point.
Reference Documentation
- See I/A Series MicroNet BACnet Wiring, Networking, and Best Practices Guide (F-27360) for detailed recommendations.
