How are the MD range of actuators attached to a damper?
  • How are the MD range of actuators attached to a damper?
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-11 07:10 AM
Fixing MD actuators to a damper.
MD10
MD20
Damper
Accessories
How is the actuator fitted to the damper?
To attach the MD actuator to the damper, it is clamped to the damper shaft, and the anti-rotation bracket (supplied with the damper) is fitted. The following range of damper accessories are available.
To review the accessories, please click HERE.
To review the MD datasheets, please click on the appropriate MD. MD10A-24, MD10B-24 (230), MD20A-24, MD20B-24 (230)
  • Field Devices
  • 15904
