Heat will not turn off on SE76xx RTU Room controller
  • Heat will not turn off on SE76xx RTU Room controller
  • SESA116857
    SESA116857
‎2018-09-06 09:53 AM
The AO output on the SE7600 controller is either off or on instead of modulating.
SE7600F Room Controller
The SE7600 Room Controller is expecting a Discharge Air Sensor to be connected in order to detect minimum heating temperatures. While this is missing it will not modulate the heat based on room demand.
Install a 10k Type 2 Discharge Air Sensor between the DS an Comm terminals or add a 10k resistor to allow the unit to modulate heat based on room spacetemp.
  • EcoStruxure Building Expert
  • 14955
