Having a mix of Cyberstation versions on the same system
  • Having a mix of Cyberstation versions on the same system
‎2018-09-09 09:46 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:43 AM
Is it possible to have different software versions on the Cyberstation workstations?
Andover Continuum
  • Continuum Cyberstation
When adding an extra workstation to a system does it have to match the version of existing workstations?
All workstations on the same system must be exactly the same version including any service packs. This also includes Web Client servers.
You will either need to install the same version as the rest of the system or upgrade all other workstations to the latest version, although this may need an upgrade of the security keys.
Cyberstation software can be downloaded from The Exchange Download Center.
Tags (2)
  • 5250
  • RamaAly23
