Graphic Lines do not Update
  • Graphic Lines do not Update
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:10 PM
Do you have graphic pages and lines that do not update after an upgrade?
  • I/NET Seven
  • Windows PC
  • Graphic pages
The following is the minimum requirements for any PC that is going to run I/NET Seven.
  1. Pentium IV (2.500 MHz).
  2. 1 GB RAM.
  3. 3 GB of available hard drive space. The Hard Drive should be 120 GB or more.
 There is one primary reason for this:
  1. Insufficient Memory: - Check the memory of the PC and verify that it is sufficient for the I/NET Seven Application.
  2. Explore into the hard drive C.
  3. Go to Properties and look at the physical description of the drive.
  • TAC INET
  • 1819
