Graphic, Dynaview, Actipane Alarm and Logging Data Stops Updating
  • Graphic, Dynaview, Actipane Alarm and Logging Data Stops Updating
  • CraigEl
    CraigEl
‎2018-09-09 09:27 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-20 11:46 PM
After a period of operation, graphics, Dynaview, Actipane, alarm, and logging data may stop updating in Sigma systems.
Satchwell BAS & Sigma
Satchwell Sigma
This issue is typically caused by the controller communication buffer not clearing. A common scenario is when engineers temporarily use their laptops as Sigma servers and later disconnect them without disabling logging or alarm routing. As a result, data continues to be routed to non-existent servers, causing the buffer to fill up.
Follow these steps to resolve the issue:
  1. Check Controller Alarm Buffer
    • Perform a controller stat (F3) to verify if the alarm buffer is retaining data.
  2. Attempt to Clear the Buffer
    • Use the ‘Request Deferred Logs and Alarms’ function.
  3. If Unsuccessful, Proceed with the Following Checks:
    • Ensure logging and alarm routing information is correct for the active server.
    • Verify the tolerance settings for analogue object values.
    • Confirm that controller backup/default servers are correctly configured.
  4. Clear the Controller Archive
    • Use the SDCU utility (Advanced option) to clear the archive.
  5. Cold Start the Controller
    • Perform a cold start and allow the server files to download again.
Additional Notes
  • Always ensure temporary servers are properly decommissioned by stopping any active logging or alarm routing before disconnecting.
  • Regularly monitor controller buffers to prevent data loss or system lag.
  • Satchwell BAS & Sigma
Tags (2)
  • 5232
  • CraigEllis25
