Getting an IDisc Wand to work after an upgrade from I/NET 2.XX to I/NET Seven
  • Getting an IDisc Wand to work after an upgrade from I/NET 2.XX to I/NET Seven
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:06 PM
I/NET Seven
IDisc
  1. Go to I/O Server and look at the Peripherals Section, Select the correct type of reader (IDisc) and the COM Port (Com 1 or 2) for communications.
  2. Go to Access, Options, select the supply card number from reader and check this box. It will probably be grayed out.
  3. Read a card or IDisc and see what happens. If it is set up correctly it will work, if not recheck the settings.
  4. Verify that the Individual Option is set for Individual as the selection.
  • TAC INET
  • 1979
