Getting Errors when attempting to open WebReports
  • Getting Errors when attempting to open WebReports
  • David_Kendrick
    David_Kendrick
  • Derrick_Ratliff
    Derrick_Ratliff
  • Benji
    Benji
‎2018-09-11 05:27 AM
Last Updated: Admiral David_Kendrick Admiral ‎2023-04-25 06:26 AM
Users are getting two possible errors when trying to open WebReports page
Error #1 - "The Web Site URL for Reports is not configured. Please contact the administrator"
Error #2 -  "The webpage cannot be found" can also be generated.
Web Reports
These Errors can occur when the link to the Reports Server is not correct.  This is usually caused by having the Enterprise Server and Report Server on the same PC
It should be noted that having both the Enterprise and Report Server's on the same PC is not recommended.
The reason the Workstation can not access the Web site / Web service URL's is because the Report Manager points to the "Localhost".  When you try to use a Workstation that is not local to the Report Server it can not locate this URL, hence the error.   This issue is not seen if when installing the Report Server on a different machine to the Enterprise Server as designed.
Even though the Enterprise Server is local to the Report Server if access required by any other Workstation or WebStation you must enter the IP or PC Name of the Report Server within the Report Manager's Web site URL.  In this instance changing only the Web site URL will rectify the problem but it is recommended to change both the Web site and Web Service URL settings. This will allow any remote Workstation / Browser to find the Report Server.
  1. In workstation, Browse, to the System folder
  2. Click on System>Report Manager
  3. Set the Web site URL to http://localhost/SchneiderElectric/WebReports/Login.aspx
  4. Set the Web Service URL to http://localhost/SchneiderElectric/WebReportsService
  5. If the Enterprise Server resides on a different PC than the Reports Server, change "localhost" to the Report Server computer name or IP address
After making this change WebReports should display correctly:
Tags (3)
  • 13749
  • 404
  • DavidKendrick23
100% helpful (2/2)
