Get the following error message when trying to access TAC Vista Webstation: HTTP Error 500.22 - Internal Server Error An ASP.NET setting has been detected that does not apply in...
  • Get the following error message when trying to access TAC Vista Webstation: HTTP Error 500.22 - Internal Server Error An AS...
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 02:07 PM
Get the following error message when trying to access TAC Vista Webstation on a Windows 2008 server:
An ASP.NET setting has been detected that does not apply in Integrated managed pipeline mode.
Vista 5.1.5
Windows 2008 server
Webstation 5.1.5
TAC Vista webstation can not handle "Managed Pipeline Mode" integrated for the application pool in the IIS.
  1. Open IIS
  2. Click on Application Pool
  3. For the Application pool used by Vista webstation set it to "Classic" instead of "Managed Pipeline Mode"
  • 4615
